Stainless
- Jun 28, 2010
- 23,671
- 9,039
What’s a good and durable brand of these?
the handle on top is connected to a rod that runs down the inside of the pipe, to a valve thats buried below the frostline. there is a drain that lets the water empty out of the vertical pipe when its not in use. saves from having to drain or blow out outside water lines in cold climates. like Wiscaaaaaaaaaaaaaaansin...Is that like a little pump or something?
What HH said, takes the place of a water spigot.Is that like a little pump or something?
yea... here they get buried at least 8' deep...What HH said, takes the place of a water spigot.
In my case it gets into the 20’s occasionally and I have to wrap the faucet and riser and these don’t need to be protected, at least in my case they wouldn’t.
Do you know of a good brand? Reviews are kinda all over the place.yea... here they get buried at least 8' deep...
Ok, I looked at them at Tractor Supply and Amazon. Thanks!i wish i had something for you. i honestly haven't heard of anyone having issues with them.
What's a frostline? I imagine its something I'd likely have to change out of my shorts and flip flops to deal with... amIright?
We have one in Green Valley now, can you believe that?There is a Tractor Supply store up in Marana, I'd go up there and ask.
I wrapped my pipes in an old blanket in the winter. Never did have a freezing issue except for the one time I didn't put the blanket on them.
I was in it yesterday and they have better prices than Amazon but I don’t know about the quality.
My motivation is not to have to wrap them every year.
We’re you still here the year SW Gas ran out of gas and there were hundreds of broken pipes in Tucson?
I’m at a higher elevation so we see colder temps, not unusual to have low 20’s and occasional teens.
Thanks Gramps!I have 5 of 'em all Merrill brand. they work good and can be rebuilt.
YepWhat's a frostline? I imagine its something I'd likely have to change out of my shorts and flip flops to deal with... amIright?
Why do you put your head in the freezer....Yep
Only frost lines I want to deal with are on my mug when I pull it from the freezer.
Because it's F#%^g hot outside, and I don't have a pool.Why do you put your head in the freezer....
Yep, that's the only time my outside pipes froze, because I didn't think of wrapping them. I had neighbors that had thrown blankets over their exposed pipes and the pipes didn't freeze. We lived up by the Tortolita's, the house was right around 3000 feet elevation, so it got below freezing quite a few times, though never as cold as that one night. Our heat stayed on at least, we were upstream of the shut off.
