Blackmagic94
- Apr 4, 2017
- 5,413
- 7,463
what is the need to have wet exhaust on a jet or v drive with an open engine bay?
Noise, wet exhaust produces slightly lower decibels and of course there's the heat thing. Wet headers don't burn as bad when you accidentally rub up against them.
Will save passengers in the back from getting scarred for life if they brush up against them!
OuchMy wife learned the hard way. Lost her balance and sat on them. Had a few weeks of blistering and sulfur bandages.
When i had my Sprint, i ran dry mainly because the water made such a mess on the transom, but the headers were cut down View attachment 775162
Should be no issue with rust if running a stainless header anyway. Not sure what material header Jet bote guys are runningSeems like issues of rust don’t outweigh the benefit on this application
Damn, that Stings just looking at it. If you run dry sooner or later you will get bit. Even a small bite will take the wind out of ya!
I have seen that video a bunch and thought “damn those 525s sound good!” Now I know why! They don’t all sound like that lol...I dry piped my twin engine Daytona with 525’s and it was loud as fuck. Totally rad.
Actually they are dry piped but I had Imco drill a tiny hole at the very end of the pipes so I could slip in the Gattlin mufflers when I went to Tahoe. The water you see is coming out of the little holeThat exhaust has water coming out so how is that dry?
So water is injected at the tip, or ?? You weren’t running the Merc tubular headers dry right? Just no water injection at the elbow ?Actually they are dry piped but I had Imco drill a tiny hole at the very end of the pipes so I could slip in the Gattlin mufflers when I went to Tahoe. The water you see is coming out of the little hole
So the headers and tips were water jacketed and then there was a quarter sized hole in the bottom of the exhaust tips where the water exited. And then a tiny hole cut on the inside to slip the mufflers in an bolt them in. I’ll try and find a pic of the set up. All I know is that when it was dry piped it was deafening. I remember Kenny at eliminator saying are you sure you want to do that. LolSo water is injected at the tip, or ?? You weren’t running the Merc tubular headers dry right? Just no water injection at the elbow ?
The headers were still water jacketed though right, and it just wasn’t mixing into the exhaust stream till the tip? Should have named it “just the tip”So the headers and tips were water jacketed and then there was a quarter sized hole in the bottom of the exhaust tips where the water exited. And then a tiny hole cut on the inside to slip the mufflers in an bolt them in. I’ll try and find a pic of the set up. All I know is that when it was dry piped it was deafening. I remember Kenny at eliminator saying are you sure you want to do that. Lol
If you like headers that are blue and brown, go for it.LOLMy stainless marine injects via multiple holes at the end of the tail pipes but there is still water going through the exhaust. To me a dry exhaust is a cry style. Zero water or water jackets.
Of course there is the whole reversion issues as well.
AZ has no such rule
Go big or go home.
You have a cigarette. Make that jet as stupid as possible...fuck it
Did you put a gas pedal in it tooI dry piped my twin engine Daytona with 525’s and it was loud as fuck. Totally rad.
Bet that's not the only thing you've dry piped! LOLI dry piped my twin engine Daytona with 525’s and it was loud as fuck. Totally rad.
I have 3Most the kids I grew up with would disagree. Lol
I know plenty of guys with the Bassett tattoo
That's BadassI dry piped my twin engine Daytona with 525’s and it was loud as fuck. Totally rad.
What boat is that engine it? It looks really cool. Inquiring minds need to know.Water jacketed dry pipes like Stellings produce over 100 dB. We changed it out to aluminum risers on the ZZ572 in my buddy's boat, after marina complained
wet exhaust, we had Eddie marine made tall risers to combat reversion.
No, what you see is the tail pipes of the Stelling dry exhausts with flappers in them.What am I seeing on the white boat with the two glass engine hatches open, looks like twin jet drives?
Is that a different boat?
I think those are the exhaust tipsWhat am I seeing on the white boat with the two glass engine hatches open, looks like twin jet drives?
