Blackmagic94
- Apr 4, 2017
- 4,808
- 6,596
Can a marine oil cooler be used as a fuel cooler?
Why do you want to cool your fuel?
I think it would be kinda large and overkill? They do make small fuel chillers
bucket of ice with fuel line coil, should get a couple runs of condensed fuel,
let us know what you do, and how it workedNot gonna work for a day on the lake. But 60-80 degree lake water will do the trick
I'm looking into this as well. I have the goofy VST system on the formula and it will vapor lock on a hot day. Aaron at absolute had an idea once, it was a small cooler and aeromotive filter but I can't remember much details past that. Might be worth a call to absoluteCan a marine oil cooler be used as a fuel cooler?
A fuel cooler will not help prevent vapor lock, think about it vapor lock happens when the engine is off and the engines heat sink effect cause the vapor lock.
Cool fuel increases it's density in theory and was the buzz in the dark ages of pro stock drag racing, in a pleasure boat I would spend the money and effort into an upgraded ice chest to keep my beers cold.
Why not an intercooler?
He’s going to be pushing around a shitload more fuel than a carbed engine, and that will heat up the fuel quite a bit so he’s starting at a disadvantage.
@Blackmagic94 I’d insulate the supply line from the surge tank to the engine for sure, and also where you place the regulator will probably be important, and running the return back to the main tank may be what you want to do.
With all the boost n parts yore throwing at it why not run E85 or methanol
I don’t remember you running an intercooler? I always ran one on my blower motors and never felt I needed to cool my fuel. That’s asphalt racing stuff. Why not use the lake as my ice box.
If you’re into compounding as many challenges as possible then this fuel cooling deal is right up your alley.
I’m failing to see how an intercooler is gonna prevent hot fuel? I’m not concerned about air charge temperatures because of the fuel. You understand that meth/water injection drops almost 100 degrees out of the charge temps.Intercooler is the way to go!!! How many other blown gas guys run a fuel cooler???? None that I know of, buy that and be done, I run almost 1400hp without a fuel cooler and have never had 1 issue, valves never move, oil is always the same, be done with it and buy a chiller... you'll never look back...
if you're running EFI then isolating the fuel rails from the hot intake manifold will lower the temp of the fuel dramatically. You can remount the rails using delrin, teflon, or phenolic material. I did on my roots blower setup and it dropped the temp of the fuel by 40 degrees.
I’m concerned about making fuel pumps run cool and not die from over heating and ruining my day on the water
My question is why is all this needed? Makes me wonder if I set my boat up wrong.... did I miss something??? Usually you set your tune on the dyno unless I missed something???
Sounds about right. Way over engineering this thing!He got a blower for cheap and threw it on a stock long block (maybe cast pistons) and trying to make it live
looks like the ice bathfound this
to much drag, with that mounted to the hullWouldn't a small transmission or power steering cooler work ?
Do any of stock NA Mercury motors come with a fuel cooler ? I've never known anyone with an EFI setup to have a vapor lock issue.
That having been said Alexi put one on my boat for insurance was the way he put it.
Lol water meth injection is my intercooler.
the blower has nothing to do with me wanting not to over heat the fuel via 3 fuel pumps other then BSFC. Even Mercury runs fuel coolers on their oem motors so this is not some nasa type idea.
Oem Mercury v8
Oil cooler
Power steering cooler
Fuel cooler
Coolant heat exchanger
Oem Mercury v8
Oil cooler
Fuel cooler
However you want to over engineer this thing have at it. It’ll make a very interesting thread. I’m just trying to wrap my head around the why on a 70mph boat?
What makes you think i want to only run 70s?
In that hull? I’m all ears lol
Well, if the cooler fuel lowered the discharge temp of the blower (which it can to some extent, as the colder fuel atomizes with the inlet air lowering inlet temps), and that small change happens to bring the motor back from the brink of detonation...........How does cold fuel make an engine last longer. Love to hear this logic lol.
Well, if the cooler fuel lowered the discharge temp of the blower (which it can to some extent, as the colder fuel atomizes with the air), and that brings the motor back from the brink of detonation...........
I guess that would be the logic!
