dirtslinger2
- Mar 8, 2011
- 2,041
- 4,767
From Nick (Chupacabra)
The first leak of fluid was indeed a loose hoes clamp on the coolant overflow, We lost maybe 2-3 ounces total and discovered when we removed the bed and rear side panel to access the PS reservoir.
Front diff has leaked since I took it, I think I know where it's coming from and I added a little Friday night.
PS system is self bleeding- but I have to mention RG, Brian and Daniel took all of my calls and gave me tips on how to help it self bleed, which we did, and ran all day Saturday with no leaks, on Double Sammy, and the dunes.
Steering feedback has been improved with the new servo, but they also have another item coming, I'll let them explain.
Had my spare axle so we installed the fresh unit, fairly simple and clever design, RG sent a CV boot kit Next Day Air to fix the damaged (now) spare.
I got a lot of questions about climbing performance, and I'm starting to put together my "240ish" mile review, which encompasses Havasu, local ride, and Sand Hollow weekend. Learned a ton.
Learned a ton! I lost the PS fluid, and discovered the right rear torn CV after the 20 minute ride I gave Jon Crowley. Originally we saw the pool of fluid and assumed the worst, but I lost the power steering at the end of the ride and didn't really realize. Hit 72 mph on that ride with him on the fence line, it's chewed up! I know my X3 is a 2 seater, but its laughable how much better the Speed is in that section, or any whoop section. And I LOVE that X3, its dialed as well.
Most importantly the suspension and handling:
Stock spring rate, crossover ring height, and Comp/ REB settings are FANTASTIC. Only downside is the stock springs loose height. RG told me we need to be at 16" WITH PEOPLE IN THE CAR, so we had it at 17-17.25" static when we loaded up for UTAH. The preload rings are beautiful, but also a huge pain in the ass. Give me the standard 2 rings, hammer and punch any day.
I'll put together a comprehensive video and have ready this week.
A YouTube video is going live tomorrow am regarding a "oh crap" moment I had climbing the Chute (2nd time, Saturday). The Speed can't be driven with 2 feet, I feel they created a safety setting to prevent people from blowing belts, but when you are half way up a rock slab, on the brakes for dear life, you cannot bump the RPM's and slowly proceed. I assume it's a simple ECU setting that hopefully I can have overridden, this will help immensely for crawling. I learned this the first day at Double Sammy, so the second time I ran it, I just got my lines and kept momentum on the few sections I needed to, so I wouldn't get into this pickle. I think the Speed has great crawling potential, a Diablo on 35" stickies and that magic 110" wheelbase would be sick!
Nick
Like Reply
Nick
Like Reply
